Hello
I have 2 Black Ice 480 rads, i started cleaning it with tap water + white venigar i did it 2-3 times, then i filled it with tap water and i let it run in it for few minutes, at last i used distilled water(all the time i boil the water) in the first 2-3 times i saw little flux going out, but after i just see clear water with small white dots floting so to be honest i still don't know if its just the water or the water is not clean nothing black coming out, so should i continue or thats it?
i rinse it each time i fill it of course.
Note: All parts are new.
I am thinking of just using distilled water to clean the cpu and gpu blocks but should i also boil the water and use tap water for it then distilled or just room temp distilled water for the blocks?
Thanks.
Thanks.
