Am new to the forum and OC'ing, apologies for any homework not done.
I have a new build with FX-8120 on Gigabyte GA-990XA-UD3 bios F12, with Xigmatek Aegir S128264 1-fan, all in an Antec 300 4-fan case. Cooler was properly seated on FX-8120 heatcap with ArticSilver 5, following Artic's guidelines for exposed heat pipe cooler and cpu cap bead. CPU fan is running at ~1950 rpm. It's ~20 hours into Artic's recommended ~200hr break-in period, with daily power on/off thermal cycles, and bios is saying 38C CPU temp at ambient room temperature of 76F. Is that normal/to be expected? Am I just seeing heatcap temp as reported by the bios? Note don't have OS installed yet so no other monitor sw available. Thanks in advance for any help.
