So I bought a new Motherboard and a new case and wanted to oc my CPU to 4.5GhZ, but already at 4.4 Ghz it hits about 58-60 degrees I'm not even sure if it won't hit over 62C after 6 hours or so! I used this guide as OP seems to have the same board as me. So I got all settings as in this. My case has pretty bad airflow I think but shouldn't my Evo cool it really good at this frequency? Also the highest voltage I can go is 1.38V otherwise the temps go above 62 in Prime95 small FFTS :O What could be at fault here? My chip? My airflow? My bad PSU? Would be nice if I could get things cooler somehow but I can't place a fan behind the backplate so the socket will get cooled, as the gap for it is way too big on my case. Right now I'm running a prime95 test @1.344V guess some cores will fail after 1h30min right now I'm one hour in.
Edit: Signature doesn't show. Here my specs:
CPU: Amd Fx 6300
GPU: XFX HD7850 Core Edition 1GB
Cooler: Coolermaster 212 Evo
PSU: Corsair CX600 (V2 I think)
Mobo: ASUS M5A99FX Pro R2.0
Case: Corsair Carbide R200
RAM: Crucial BallistiX Sport 4GB 1333MhZ
CPU: Amd Fx 6300
