- Jun 15, 2003
- Cedar Rapids, Iowa
I just switched processor/motherboard from a 144/DFI to a 148/Epox and strangely enough, the 148 is idling ~ fairly high (20 to 40C) where the 144 used to idle fairly low (-30 to -20C). The only other thing that I've changed is that I've moved and when I moved I've positioned my system differently.
Before the move I had everything level in a chest. The motherboard sat flat at the bottom of the chest and so did the compressor/phase stuffs.
After the move I now have the phase system sitting on a small table (about 2 foot high) and my motherboard above it on my desk (~ 3-4 foot without measuring). The suction line is long enough to point upwards from my phase system and arc up above where my motherboard is now and bend back down to my processor.
The temp probe on my evaporator is reading somewhere < 50C but my processor is way, way above that in temps. The evap is a cap-in-cap design with a hole drilled at the top corner of each cap.
Another strange thing -- in trying to figure out what's going on I started adding more propane to see if I needed a bit more kick in the system in case a schraeder valve leaked some refrigerant, what came out was refrigerant and some oil with it (splattering all over, and also misting into the air and then dripping out of the hose once I had closed the manifold's valve). Could the new positioning be causing oil build-up or something?
I also thought that maybe oil was collecting in the bottoms of the caps in my cap in cap evaporator, and the refrigerant was escaping through the holes in the top of each cap before getting to the copper baseplate. My evap temp probe is located on the top/side of the outermost cap so that might explain the low probe temps and high processor temps.
I have also remounted the evaporator well over 10 times trying to figure out if it was just a mounting problem. Even popped the top off of it! The temp has varied a bit between mountings but still nothing near what it should be.
Anyone have any advice or ideas? I'm just an ignorant experimenter when it comes to this phase stuff so I can't say that I know exactly what I'm doing all the time, heh.
Thanks for your help and for the read,
Derek
Derek
