- May 15, 2010
- Euroland, Denmark
Hello guys,
I am having some really strange issues with my pc.
Setup:
I7 5930k
Gigabyte x99m gaming 5
4x 4gb Corsair Vengence 2133mhz ddr4
Samsung 840 ssd, 120 and 256gb.
2x Gtx 980
1700watt psu.
Background:
Last night i was on the playibg and later watching a stream. Went to turn off pc and it had an update, so i pressed update and shut down. Went to bed.
Current situation:
Come home from work, turn on pc as normal. I leave the room, come back about 2 mins after, and the pc is going in repair mode. I figured windows update failed, as it so often does, so i let it roll out to where i could roll back drivers. This failed, i then did reset windows, but keep files, failed. I then reset bios, and looked, the pc couldnt see any of my ssds on the bootable menu, but was able to see them fine on the sata channels. Odd..
I had nothing of importance on c: so i booted up windows 10 installer with usb, attempted upgrade, no luck, install on ssd, which were showing up there too. When i clicked my ssd it said i could not use it, as it was MBR or something i delete alle partions, and then it was okay to install.
Got into windows, but with a few more random restarts in setup process than normal. Didnt think more of it, and started to update. Suddenly, black screen, and then restart, and the whole repair process and unable to see the ssd as boot drive came back.
Hmm dead ssd? I took my other ssd, ran it alone, got into windows via install and this time i only went to updatr gpu drivers. During install crash, back to repair, with no bootable option for the ssd. Hmm.
Did another install, only installed crystal and magician, to check ssd health, perfect health, on both ssds.
I then figured, did both ssds die?
Used an hdd, this time, less random restarts durinh install, but non the less, they happend. In windows, driver update, crash, same story.
Okay, so by now, i think all my drives are working, issue is gpu. But why does this screw up bootable drives?
I disabled one gpu, at a time, tested, with reinstall ofw10 every step of the way.
Same issue. Both gpus as main.
Motherboard? Updated bios, same issue.
Happens with every install, and screws up when i install gpus.
I dont have spare gpus to test, but surely there must be a different culprit?
Could it be PSU dieing?
Setup:
I7 5930k
2x Gtx 980
1700watt psu.
Background:
Current situation:
