Do you think adding heat-sinks to the VRM might help? (cant see it hurting anything)It's very possible that you're making the motherboard's VRM overheat and shut down the system.
The 1100T takes some power, and that motherboard has a *much* less than stellar VRM.
Now that I think about it, I am surprised that MB manufactures don't heat-sink all VRM's. I have started dabbling with building my own Audio amplifiers - including the power supplies. And I know that the voltage regulators get hot under load. No heat-sink = fried component. (learned the hard way during a test...)
The Erthwatts is fine, but the EVGAs listed, particularly the G2 for the same exact price and much longer warranty, is better.
Just found this... shoud I be concerned..... http://www.overclock.net/t/1476935/why-you-should-not-buy-an-evga-supernova-nex650g-750g-aka-g1
The link I put in here is to the G2, not the G1.
I would try cooling off those vrms with spot cooling first... absolutely.yes I noticed that. bookmarked. I really wish to fully test my current psu before I spend a large chunk of change.
Ive been having some odd "power related" issues that (based on what Ive read) seem to be evident of a bad or dieing PSU. For example when I push the power button fans spin up and then dies.. Random shut downs. Or just wont turn on.....have to wait hours to days before it turns on again. (this has happened with 2 motherboards - different revisions of the same Gigabyte MB - the issues became most prevalent after I upgraded to the 1100T CPU)
► Now I have had to splice some of the wires due to insufficient length. I intend to completely remove the unit and check all splices to make sure there is no shorts (but I am extremely careful when I make any electrical splice) - I also should check the relay that turns on the blower...Possibly replace.
I have ordered a PSU tester to help diagnose any possible issues. But that wont arrive until next week. I also intend to check it with my Multimeter.
One other thought I have is: Could I be overloading one of the 12v rails? How does one know witch rail they are using? (since I assume that it should be as balanced as possible)
Well I just ordered the EVGA SuperNOVA 750 G2 https://www.amazon.com/gp/mobile/d...l&asin=B00IKDETOW&clickstream-tag=your_order for $128 after tax and shipping. I hope I got a fair deal...
I decided to get the 750w over the 650w for future head room.
