- Jul 18, 2004
Hmm, well, for now I'm running my subs out of the sub-out on my audigy 2. Sounds good, I have bass re-direction at 65 hz because the speakers (mains) are flat (-3db) down to about 35, so I figure the 2 subs can pick up at about 65 and the mains can start dropping off there. 80 hz is thx standard but I've tried that and I don't like it.. heh.
However, this fall I'll be moving back to college and the speakers will be out in the common room. There will be multiple input sources so I'm not quite sure how I want to deal with this. In all probability I'll build an RCA switching box for the inputs and only have one input on the receiver and one input on the subwoofer amplifier.
So I'll have multiple RCA's coming into the switch, two channels coming out. I'm then either going to integrate a linkwitz 2 - way crossover in the switch or make that an external box.
But basically, I probably want to have a linkwitz crossover at 65 hz with a SLIGHT boost on the lower end approaching 20 hz, but nothing extreme. I probably also want to go with a 12 db / octave cross-over, so 2nd order. I have some experience building crossovers but have never tried a linkwitz before. And, I've never done an RCA crossover. Is the signal strong enough to tamper with without a line driver? Or will I need extremely sensitive components + a powered unit?
My reason for doing this is that although the Mackie and the plate amp have crossovers there's still a lot of leaking, which makes me think they are only first order, which isn't enough for a sub. I don't want vocals to ever come out of my subwoofer, lol.
Hopefully ryan will have some input.
