Hey guys,
This is my first post on over clockers so be gentle
So I just bought a Corsair H100i and I'm wondering what would be the best air flow for the case? Specifically should the water cooler be exhaust or intake?
Here is my case
http://www.newegg.com/Product/Product.aspx?Item=N82E168...
It has
Front fan:1x200mm
Side fan:1x200mm
Bottom fan: 1x120mm
Rear fan:1x120mm
top fan:Corsair H100i
What do you guys think should set up as exhaust and intake?
Also if I can fit it…would you guys recommend a push/pull configuration for my H100I?
If I setup my top fans as exhaust it would pushing hot air onto the radiator right? This is where I get mainly confused...
Thanks for any answers and or suggesting y'all might have!
Cheers!
Here is my case
It has
Front fan:1x200mm
Side fan:1x200mm
Bottom fan: 1x120mm
Rear fan:1x120mm
Cheers!
