- Jan 12, 2013
- Pittsburgh, Pa
Hi guys,
At the moment I am using a HAF912. I have a Swiftech H220 AIO water cooler installed on top of the case in a push/pull configuration. Two Swiftech Helix 120 PWM fans are installed on the inside of the top of the case doing the pushing. Then, I have the radiator installed on top of the case with two Swiftech Helix 120 PWM fans pulling the air. The rest of my case fans are Swiftech Helix 120 PWM fans as well. This case gets really dusty for me even with Silverstone fan filters installed. The filters do not work very good for catching fine dust particles. I know they say a positive air flow can reduce dust. However, in order to achieve positive air flow the only way I could do this is by making my rear exhaust fan a intake. Then, I would have just the radiator fans on top of my case removing heat from the case. This would give me 4 intakes and 2 exhausts instead of 3 intakes and 3 exhausts. Would it be okay to flip the rear exhaust fan around? Do you think this would actually help with dust? I do have an extra fan filter for the rear if I should flip it to intake.
As the title says I am also shopping for a new case. I am sick of how hard and complicated it is to tear down my current system with the Swiftech H220 having to be rigged up on top of the case. It is a pain to detach and reinstall when cleaning. Plus I just do not like the look of it on top of the case. I am aiming for a cleaner look with everything inside the case. My house gets really dusty for some reason so I need a case that has good filtering capabilities and does a good job of keeping the dust out. I also do not want to go shopping for new fans. So the case will need to be able to except my Swiftech Helix 120 PWM fans. I have like 10 or 12 of them laying around. I would like to put them to good use. Also, I am looking for a case with a nice window. Is there a case that will fit a 120x4 rad inside in addition to my Swiftech H220 AIO kit, that has good fan filters, a side window, and excepts 120mm fans? The reason for the 120x4 rad is I have two Sapphire HD7970's I want to water cool. I also do not want a case I am going to have to chop all up to get this stuff to fit. Is there any cases for under $150 that can achieve this?
Thanks,
Rocky
Thanks,
Rocky
