- Jul 26, 2001
- Houston, TX
I recently acquired a Danger Den Maze3 water block for my AMD setup.
It is moderetly OCed, it is a stock 2100+ 1.60v 1.73GHz @ 2700+ 1.65v 2.17GHz. My cooling setup is in my sig. I am usually about 12-15 C above the room ambent @ idle, with full load temps another 5-8 C higher, and the inside case temp is about 10C over the room ambient.
Here lately it has been between 25 and 30 C in my room and the temps are in line as above.
My question is this: With the Maze3 (1/2" fittings) and a chevette heater core what size pump should I use? Due to my budget I will most likely be purchasing one of the Hydor pumps form Danger Den. As my current plans go I will mount, somehow, the heater core inside my pc and blow air out of the pc through the heater core. To help with cool air, I plan on cutting a large rectangular hole in a case panel and use some filtering material to filter the air before it enters the pc. I plan on the hole being at least 12" x 3".
Secondly I would like to keep the noise down, reason for moving to water cooling. I also plan on using a 120mm x 38mm fan, with speed adjustment. And include the pumps inside the pc case.
So thus, which pump should I use? How much noise difference is there between the L20 and L30 pumps?
Thanks for the help.
