- Feb 20, 2009
- Sacramento, Ca
Hi all,
I bought a new Corsair 750D case and wanted to install my water cooling system. During install, I realized that my XSPC RX360 with 3 gentle typhoon fans won't fit up top in the spot allocated for the radiator. It puts a slight pressure on my 8-pin cpu power connector on the motherboard. I'm pretty bummed about it since it's fairly new. Now it's off to the classifieds and I guess I'll have to go with a slim line radiator.
I've done some brief research and it seems some of the slim lines can still perform well. It looks like the swiftech MCR360XP rads perform very well and the RS line isn't far behind. I'm using gentle typhoon 1850rpm fans. Will these work with the XP series radiator?
Anyone have experience with these or suggestions?
My loop will cool an i7-920 overclocked mildly and a 480GTX. Both run hot. I have a second radiator in the loop which is a swiftech 220QP in a sort of push/pull setup. I say sort of cause I'm using the stock 2 140mm fans to push air in while the 2 yate loons pull.
CPU block - Apogee XT (secondary config for compression fittings)
GPU Block - EK acetal 480GTX full coverage block.
Pump - swiftech D5 vario
Any help or suggestions would be greatly appreciated.
