- Jul 13, 2005
ok here's my rig setup:
A64 3700 San Diego @ 237x11
asus a8v deluexe obviously
2x512 Kingmax pc4000 (super nade you specifically mentioned this model of ram as working with this motherboard)
MSI 6600GT agp
EDIT: running 1013 bios, 1014.007 beta is available, should I flash it?
Ok aside from the htt mentioned above the settings are as follows:
vcore 1.55v
ddr volt 2.8v
agp 1.6v
agp frequency: I've tried all three settings and they don't seem to make a difference with my problem
memory settings:
limit
2:1
timings: I've gone from 2.5-4-4-7 all the way to 3-6-6-15 incrementing by 1 at a time and each setting 1 at a time and running prime EACH time. I failed EVERY time.
2T is disabled
burst whatever is at 8 clk
now, simply change the mem setting to 1:1 and I pass.... I've tested my cpu extensively and I pass prime no matter what the circumstances until I change the memory setting to 2:1.... I fail the first test and I also get a memory address error in counterstrike: "this address xxx referenced xxx and the program must be shut down" or something to that extent... I've replaced the memory, power supply and still no luck.. I've run memtest up to 250Mhz on my ram and there's no point in testing it further because I don't WANT to go farther. since you seem to be an expert on this board, could you give me some suggestions? Thanks for the help.
See that's my memory, Kingmax pc4000...
MSI 6600GT agp
vcore 1.55v
ddr volt 2.8v
agp 1.6v
memory settings:
limit
2:1
2T is disabled
Super Nade said::: MEMORY COMPATABILITY SHEET::
Apart from the Official ASUS Compatability sheet on their website, these modules work and more importantly, these have problems. These modules are reported unsatisfactory or not running at rated frequencies, but the user may not have tried relaxed timings or increased VDimm.
New!!!
GSkill Rep says TCCD won't OC well with this MoBo! Look in the latest issues section for more information!
1. Corsair TwinX 1024-3200C2PT
2. Corsair xms 3200
3. Kingmax PC4000
4. Mushkin LVl II Black (BH-5)
5. OCZ pc3700eb
6. OCZ EL Rev.2
7. Corsair Platinum Edition PC4000
8. OCZ Platinum 3200 Rev.2 TCCD
9. Geil Golden Dragon PC3500
1.PDP/Patriot XBL (The 2-2-2-5-1T modules)
I personally have had problems with these modules, so beware. It maybe a bad batch of RAM but nevertheless this is on the iffy list.
(Edit*Confirmed problematic RAM)
1. ADATA PC4000 (Mr.Joor)
2.Gskill pc4400 (Mr.rdrash)
3.PDP XBLK (Samsung TCCD 2-2-2-5-1T)
