Which one will be better assume both will be mounted with the same 92mm fan.
This will be install in Pentium 4 system which is very highly overclock ( 1Ghz overclock to be exact )
which will give me the lowest temperature ?
thanks.
Well I only have seen a couple things on the swiftys but they were all good. For one thing it is smaller so it might fit your board if the 900U doesn't. It also leaves the ability to make a peltier in the future without having to buy a new heatsink if I remember correctly. Your fan will make a big difference also though.
