- May 22, 2011
- USA
MCP50X Pump
Maelstrom V2 Dual Bay Reservoir
H220-X CPU Liquid Cooling Kit
Really excited to see some these products released especially the long waited MCP50X pump.
Kind of bummed the reservoir doesn't support dual pumps, at least for the time being.
Also excited to see more competition with the H220-X AIO cooler. I'd like to call it a beginners kit to custom cooling because of its expansion capability. This should compete really well versus the XSPC kits that go for more than this AIO. This kit, I'd like to call it, comes with a much better pump, better fans for example than the pricier XSPC beginner kits. A D5 XSPC kit will cost you $220+. Should be interesting to see how this unfolds in the future.
P.S. - Lets hope there's no patent trolling in the near future or anytime for that matter.
Small Footprint: 2.4" x 2.4" x 1.8";
50,000 hours MTBF (Mean Time Between Failure) ;
12 Volts DC
SATA connector
Variable speed control via PWM thru the motherboard, from 1200 rpm for completely silent operation, to 4500 rpm for ultra high flow performance;
Superior head pressure to any pump in the same class and footprint: the MCP50X is particularly well adapted to support multiple devices in the same loop, such as multiple radiators, and/or waterblocks;
G1/4" ports standard for compatibility with a large assortment of fittings;
Quick installation with adhesive neoprene pad, or permanent installation with supplied hardware;
Optional "built-in" reservoir;
3 year warranty
Functional Features Benefits
Clear acrylic construction Visible coolant level
Flow path control Anti-vortex pump intake partition
Push and twist fill-port cap Tool-less, ease of use
Dual flow return ports Loop parallelization option
Standard CD/DVD mount points Universal compatibility
Performance Features Benefits
Buil-in MCP50X pump Extreme pressure (4.8mH2O) pump for the most complex loops
PWM control Speed adjustable from 1200 to 4500 rpm for flow and noise control
Cosmetic Features Benefits
CNC machined and black anodized billet aluminum face plate with silk screened level Hi-tech custom look
UV LED included Glowing coolant with UV reactive additives
CASUAL USERS
The kit is shipped factory pre-filled, ready for plug-and-play installation, and it is maintenance free during its warranty period.
Both Swiftech's powerful MCP30 pump and high-pressure Helix fans are PWM compliant devices, allowing the H220-X to be recognized and speed-controlled by the motherboard depending on CPU temperature, just like a regular cooling fan.
As a bonus, the system also includes our PWM splitter allowing connection of up to 8 PWM devices which can then be controlled as one by the motherboard.
Finally, thanks to a clear and user-friendly pictorial installation guide, it could not be easier to install and setup!
ENTHUSIAST USERS
The system can be entirely customized thanks to easily replaceable tubing and fittings.
Thanks to its powerful pump it can support additional liquid cooled components such as graphics cards and/or additional radiator(s).
The factory fittings can now be upgraded to any G1/4 compatible after-market fittings (an optional adapter is needed for the pump outlet and will be available shortly), which will allow enthusiast users to upgrade their system to 1/2" ID tubing if they wish to.
