- Oct 28, 2017
WELCOME!!
okay, so I decided to give it a go! Downloaded zorin os because I liked how it looks and burned image to DVD. While at it, I also downloaded nvidia Linux driver, latest version! Heh, funny...its ".run" extension?
Fast forward few hours. O Y E !!
I got her installed no problem, but when i wanted to install nvidia driver that's when things went to a screeching halt! BAH!!
First I couldn't figure out how to run that nvidia file because it kept opening up as text document. right clicking and letting it "run" was helpful, but not. When I clicked it to run, it wouldn't install because needs to be in root folder? Okay, BUT it won't let me access!! Off to internet.
Okay, I found "soid" command into "terminal"?? Anyways, something super user whatever stuff...but again!! It says something failed and then by continuing, it says can't disable some sort of kernel driver nouveau? Then it says nvidia helped by adding that file for you, but try restarting??
Okay, restart. Oh, command line!!! Let's try from there!! Meh, it says command not recognized, then syntax is wrong, then can't find file. Okay.
I'm back in windows. Er I mean zorin. I tried again and same thing. Okay, lets try to tether phone to internet through USB and see if online installation from software+updates >>additional drivers can work? Okay, looks like there is a driver, but its not super recent? No worries, as long as its proprietary, uh right?
Well, I tried and it just sits there. Maybe because I tried terminal bunch of commands and broke everything??
stand by for updates...thanks for reading. Please don't laugh, or do so lightly or so I don't hear it.
WELCOME!!
Gahh, okay, lets reinstall and try from scratch that internet version of driver..
