- Jan 14, 2003
- Melbourne, Australia
Hi all,
I just ordered a 2100+ AIUHB (not sure what week yet) and I am going to put it in my A7V133. The mobo has the right clock generator that is supposed to work with XPs and jumperless mode, but the problem will be setting the multiplier (If indeed the chip works at all!). In the BIOS I can not get a multiplier over 14 (some lower ones are remapped to 13 and 14 in the bios) and I will probably want a multiplier of around 17 (FSB will be from 133 to 150) which will give me around the 2.3G mark which seems pretty standard. Would I be better off hard coding the chip by cutting the 4th L3 bridge to make the multiplier 17 (giving me an OC range of 2261Mhz@133FSB to 2550Mhz@150FSB) or should I enable the 8x bit so all my multipliers are +8 and set the multiplier in the bios to 9X (9+8=17). I think the 8x bit would be better but I'm not sure exactly what I need to do. Also, what is the best way to cut a bridge with out any specialist tools (does using a 9v battery work well?).
Hard coding tbred: http://www.ocinside.de/go_d.html?/html/workshop/socketa/tbred_painting_d.html
http://www.beachlink.com/candjac/TbredDecode0.htm#Table
setting 8x bit: http://www.beachlink.com/candjac/MultiCode.htm#Pic
Thanks in advance for any help
Floopyb
Floopyb
