PART II:
Again, no flame. That's YOUR problem for mis-interpreting my post.
actually... you mis-interpreted what I was getting at.
your entire posts in this thread is highly defensive. Anything i've said to you, you take it badly, as if holding a grudge.. and very, very defensive.
Who's said this?? read-->
Originally posted by james.miller
excuse me mister arrogant. read my sig:
2x256mb twinmos pc3200. DUAL CHANNEL.
damn it. if i wernt such a nice person, i'd call you an idiot you're attitude towards people really irritates me.
btw, i know more than enough about overclock.Remember, you are in NO WAY abouve me, or anybody. SO again, please stop
it.
umm.. i think you are the one needs to "stop" it.
APIC is disabled - and always has been, since i knew about the problems before i even brought the board. Is that
serious enough?
OH, and, i seem to remember other people having exactly the same problem. hmmm.......
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=222154&highlight=interface
metalStorm has seen it.
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=221258&highlight=interface
Gautam experianced it first-hand.
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=220064&highlight=interface
the_poche - couldnt boot at 220mhz with it.
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=212316&highlight=interface
Audioaficionado cant use all the multi's without it. is that still the case, Audioaficionado?
all those are examples of problems with the cpu interface
disabled. I'm sure you dont need more. [/B]
08-07-2003
Sounds like Tyranos had too many sticks on the board and
expecting to FSB overclock high. Not a good idea.
Seems more mixing memory or/and too many sticks running
at the same time. someone mentioned try both CPU
interface enabled and disabled, right there.
08-04-2003
Edward2
His problem is more related with Vcore voltages. His
previous setup was Abit KX7-333 KT333 system, which
delivers healthy Vcore lines. The actual vcore usually
puts out higher than what you command in the BIOS.
For the Abit NF7 series boards, totally the opposite.
They genearally do not deliver good Vcore lines. They
undervolt and fluctate even down further. This is very,
very old talk. I had a discussion about this over a
year ago. It's been so long time.
07-30-2003
Lithan
CPU Interface being enabled doesn't necessarily make your system stable. CPU Interface On will put more stress on the CPUs in general. There are too many other variables you have to
take into considerations. A lot of times, I find that
people don't pay attention of other settings and most
often forgot their Vcore voltage isnt' enough to handle
the whatever speed they run at. They *think* they vcore
is plenty, but don't realize it is actually fluctuating
like mad and undervolts, which ultimately leads to
instability. Instabilities are presented in my forms.
Vcore is just one of the things. The key here is
consider other factors that could cause problems.
someone didnt' realize what they have changed in the
BIOS but only remembers CPU Interface was enabled, which
brought back stability. That is what I call poor
observation in attempt to troubeshooting the overclocked
hardware. This happened to many many people. I've been
seeing it all over the freakin forms.
07-07-2003
G|-|oST
You only been searching for CPU Interface?? and not
worrying about the other things???? You are getting
obsessed here. Not very good way to troubleshoot.
Look in that thread. What did Quest For Speed has said.
He says "it is for fast decode". He got that info from
me or other xtreme members at the other site. I'm one
of the persons that found this since the very first
release of Abit NF7 series revision 1.0 A2 chipset. I'm
the one(along with very few others over at abit forum)
who discovered the Vcore issue, Dual Channel issue, CPU
Interface issue, and more. This was over a year ago.
this is really, "old" stuff.
Oh yes, silly me
Think again.
