mmills said:
hitechjb1,
> Can you be more specific about what you mean by general system?
I was thinking in terms of operations reseach and/or Turing Machines.
I've got my machine running stable under Prime95 load. 2.4 gig, 218 FSB, 93% bandwidth efficiency, 3269 mem bandwidth. Using 7-3-3-2.5, vcore 1.85, vdimm 2.9, CPU temp 48 C, case 33 C.
I can't get 220 FSB to work for me.
mmills
I can see lot of interesting relationship between operations research and overclocking of CPU, FSB, memory, ... Operations research deals with mathematical programming and combinatorial optimization problems, such as linear, non-linear and integer programming to solve very large, complex real-life problems such as air traffic scheduling, communication network scheduling, oil exploration, ...
To solve large problems, the computers and programs have to handle very large, special data structures of matrices and graphs stored in hard disk, memory and cache. So faster disk, larger total memory size (GB), higher FSB and memory bandwidth (MB/s) and larger CPU cache would help these applications to move data through these different levels of memory hierarchy: cache - FSB - memory - hard disk (paging). Further, a higher raw CPU power would be desirable to number crunch the inner loop of those problems, formulated as linear programming, combinatorial search, in cache.
Combinatorial search deals with discrete optimization problem such as the travelling salesperson problem which is to find a travelling path with the shortest distance to visit all of a given number of cities (once). It is mathematically difficult to find the optimal solution, if the number of cities is very large; but it can be approximated and number crunched by using mathematical programming technique.
As for Turing machine which is a simple computation model with a very simple processor and infinite memory to study computational complexity in time and space (memory), I can hardly see any relevance with overclocking. If you have some ideas, pls post.
Back to your overclocking, running at 218-220 MHz FSB is about the norm for NF7-S rev 2.0. If you are using 3700 memory (from your sig 256 MB, too little?), have you tried setting memory to CAS2, it would help to bring the memory efficiency to 95-96% which is the top end number for the memory bandwidth for this board. What is your chipset Vdd at? A Vdd mod may help, if you want to try higher than 218 MHz. If you use 3700 memory, it should not be limiting yet.
If you are in the northern hemisphere, as days go on, we are getting better and better seasonal help for overclocking, you may be able to get above 2.4 GHz towards 2.5 GHz soon as a drop of 5 C in ambient temperature would help the CPU overclocking frequency by about 2% (~ 50 MHz), assuming HSF being kept the same.
