Greetings y'all! Really just a simple question about my overclock, temps and voltage. My rig I believe is in my sig. Running with a 4.5 oc, a LLC of 2 and 1.355 on vcore and almost an hour into P95 blend. My temps are sitting around high 70's to mid 80's I'm guessing depending on the FFT it is running. The max I have hit across all cores is 87. I will try and post pics, but not sure if I can off my phone.
I don't think I won the silicon lottery by any means and probably not going to push past 4.5 if it remains stable. I also haven't de-lidded.
I'm the event I can't get a pic posted, does it sound like it's going ok? Thanks y'all
I don't see my sig, I'm running an Intel i5 3570k, ASRock Extreme 4 mobo, hyper 212 evo cooler, antec illusion black case, AS5 was the TIM used, Antec Earthwatts 650 psu. Trying to think of any other possibly needed info.
**** I see the sig now, must be because i posted from my laptop for this and my phone for the other. Only changes are windows 7 is now 8.1 and trying for 4.5 from my 4.2
