- Thread Starter
- #21
A. As I said before, I'd rather not do any manual overclocking. I'd prefer to buy a kit that has the speed/timing I want at stock...In practical terms, considering what kind of memory available on the maket, your only choices are:
A. Good manual overclocking (run Samsung 1600 MHz @ 2133 MHz)
B. Bad automatic overclocking (G. Skill 1333 MHz @ 2133 MHz)
C. Manually under-overclocking the automatically overclocked memory (G. Skill 1333 MHz @ 1333 MHz)
If I had to overclock, I'd choose A first, no questions, especially because it has such a good track record, and 1600 MHz chips can probably run faster than 1333 MHz chips. And with those Samsung modules you'll get something that's rock-solid at 1600 MHz, no matter which sample you receive.
B. To be honest, if the "stock" speed can be changed from 1333MHz to 2133MHz via XMP profile, I'd rather have that. If it can't, I can just RMA it, right?
C. What...?
So the kit I posted will be able to run 2133mhz CL9 without any manual overclocking? i.e. All I would have to do is load the XMP profile?What on earth are you talking about larrymoencurly? G.Skill rates their sticks for what they will run. I have never had a set of G.Skill RAM fail to run its rated speed unless it was an IMC problem, from DDR2-1066 to DDR3-2666. However there is a strong potential for a Samsung 1600 kit to not run at 2133. Plus, because it's not rated for where he wants to run, he's out of luck on an RMA.
