Stilletto said:
What makes you think it was topped out at that low voltage? Heck, I need that many volts to keep my 805 stable at 3.95ghz. Did increasing the voltage not really help much or the temps too high?
temps were still below 60c, but adding more voltage up to 1.55v (IIRC) didn't provide any stable speed increases with the B1 chip...
on a side note, to update this thread:
Fry's gave me a replacement p5wd2-e for my board that had the sata connections fail...and i haven't done the pencil droop mod yet...so i was able to lower the voltage to 1.23v to get 4ghz (267x15) stable...actual voltage drops to 1.21v or so under full load....
i also now have a 540watt APC, UPS that tells me how much power is being drawn by my system:
at 4ghz, 1.23v: 270 watts idle, 335 watts full 2x cpu load
at 4.5ghz, 1.37v: 300 watts idle, 375 watts full 2x cpu load
at 4.8ghz, 1.48v: 325 watts idle, 430 watts full 2x cpu load
so about 100 more watts under full load being drawn with 800 more mhz and 0.25 more volts...
