- Feb 8, 2005
- Qc, Canada
wow, that's tight
Love the idea, can't wait to see it all finished up.
I get the idea, but how would the false floor attach? You'd either want to bolt it to something or put material between it and the case (very do-able) to prevent vibration. Bolting it to the side and putting foam/rubber under it seems like it would work pretty good. Either way, this gives me another option to think about.well since you have no clearance to fasten to the bottom of the case, make a false floor out of another sheet of metal the same size as your drive areae and then fasten it either to the walls of the case or to the bottom via something slim like a pop rivet.that way you can use standard spacers between the 'new' case bottom and the backplane cards with a female/female riser and screws on either side through the false bottom and backplane, without sticking through the bottom of the case.
[V]screw head__________________
[ backplane card-------------------]
| | nylon stand-off
[ sheet metal 'false floor'-------------------------------------------------]
[/\] screw head
--------------------------------------------- real case bottom------------
(hope this comes out right)
Unless you have enough storage to backup every drive in the world, you don't have enough.Holy shark a petabyte is a lot of space... with 3tb drives... 0.o
what would you ever need that much space for... someones trying to compete with Mega...
Unfortunately, that is the difficult part. Backblaze purchased (purchases?) them from a company on an as-needed basis. I could do the same thing, but it would cost me >$50 per backplane, which makes this the most expensive part of the project.Where do you find the backplanes at?
well if you sheet metal is larger than you need you could bend up some tabs on the sides and bolt to the front and fan divider bracketing, and possibly the case sides. as far as vibration goes, maybe something like this? either make a grid of them if they are thicker that the screw heads, of not, stick them TOO the screw heads. should take care of that.I get the idea, but how would the false floor attach? You'd either want to bolt it to something or put material between it and the case (very do-able) to prevent vibration. Bolting it to the side and putting foam/rubber under it seems like it would work pretty good. Either way, this gives me another option to think about.
+1Unless you have enough storage to backup every drive in the world, you don't have enough.
