- Feb 9, 2002
I see a-lot of recommendations for 140mm rads due to the whole no replacement for displacement argument.
But i also have been noticing even the largest cases that house 4x120mm rads can only do 3x140mm rads as the alternative, now following the rule of "no replacement for displacement" that would mean that 4x120mm is superior right?
Especially given that the Static pressure of 120mm fans is far greater also, and fan selection is better too.
So am i right to think that in the situation of say Corsair 900D or Phantek ethos primo's the 4x120mm capabilities would be the way to go rather then 140mm alternative.
The only exception i've found here is in the front intake areas where dual 140mm rads are capable and only dual 120mm rad as alternative.
But everywhere else its 4x120mm vs 3x140mm.
Just wondering if i'm correct on this outlook.
I do assume the 140mm route would make the cooling loop a-lot quieter overall however which is another consideration all together.
