R4z0r4mu5 Pr|m3 said:Also, i thought the 9500np was supposed to be have 128bit memory by default, why have they built the pcbs allowing 256bit in some 9500np but always 128bit even in the L shaped 9500pro?
Isn't the RAM on most 9500nps 3.3ns? That's pretty weird... the 3.6ns RAM on my ti4200 can go past 300 easily.But my damned memory peters out at 297. Even one more notch higher to the 303 level and it goes straight to hell after like two minutes. It's not heat-related either, because the little BGA memory modules are just luke warm to the touch. I think people have had success Vmodding the ram on these puppies to make them behave better, but honestly I don't care THAT much.
Damian said:Realize, though, that with many vendors you're not guaranteed an L-shaped PCB at all.
Damian said:1. the new 9600pros don't o/c as well as the preproduction ones.
2. even when overclocked to its limits, the 9600pro is still pretty bad.
The 9500np, on the other hand... being able to go from a $135 bottom-mid-end budget card to a $270 (previously above $300) very-high-end card is what I'd call a pretty nice modding/oc.
q149 said:The 9600's overclock LESS than 9500's on average Mhz for Mhz.... and 9600's get much less performance than a 9500 out of each additional Mhz it is overclocked.
Hurk said:
I believe the question is: What card can increased the most in Mhz from when it was originally bought.
What ever the answer to that is, regardless of performance, is the correct answer.
