Okay so my Senior Project Modular Project is all done and has been graded. After displaying it for eight advisors and industry vets from IBM and Motorola I received and A grade. It couldn't have went better for the resources I had. Now it is time to move on to something fresh and a more artistic. I have been a big fan of the Steampunk culture for awhile now (cyberpunk just doesn't do it for me) and decided to incorporate that into my next rig.
I started this same thread on Sudhian's Forum a couple days ago, so this is going to be a large post to get caught up here. Before anyone says it, yes I have seen the Steampunk Workshop by Jake von Slatt, and Datamancer.net. I will be incorporating the design into my PC box, mouse, keyboard, and speakers. I do not know if I am going to mod my monitor yet as I do not want to ruin my 22" LCD.
It will be at least a couple months before I can start acquiring parts because I am poor, but I will definitely need the time to plan how I want to put it together.
Form Factor: mITX (Flex ATX or DTX if I really can’t afford it)
CPU: Core 2 Duo (Conroe or Merom)
RAM: 2GB minimum
Graphics: 8800GTS or 2900XT (Maybe externally if possible)
DVD: Slim Laptop Drive
HDD: 3.5” or 2.5” SATA HDD
PSU: I doubt any of those little mITX power supplies will have enough power for a gaming card, so I will have to jump up to a Shuttle PSU.
The design will be my own with influences stemming from many different sources. I want to maintain the slight sci-fi feel while using normal mechanical parts. Much of the decoration will be made to look practical even though it has nothing to do with the actual PC operation. I am trying to find many of the desing parts at Goodwills and Thrift shops. Below are a metal watering can that will be cut to form a chimney and a cool bowl that will serve as a fan grill. They will need to be chemically stained to have a patina appearance.
I also purchased an old Dell keyboard that has the nice "clicky" mechanical keys. I will be buying some typewriter keys soon to replace the normal keyboard keys.
If I end up using water cooling again, I will most likely incorporate some copper tubing into the loop with some windows to prove the flow.
I am also researching miniature model steam engines to give a more authentic feel to the case. It the models are too expensive (many are over $200) I may be forced to make everything by hand and appear to be a working engine. I've been researching individual parts like boilers and I don't think it would be very hard.
I think that was about everything I have been doing over the past few days. I hope this project is enjoyable for you to watch as it progresses. It will probably be a few months before it is completed, but design and preparation process is the most important at this point.
- Doomzilla aka dotyer
RAM: 2GB minimum
