Yup, another post from me. The first part here is review. The good stuff comes @ the end if you want to skip this stuff.
As you may know, my C1.0A project did not go as well as I had hoped. I worked, but needed lots of Vcore, and the best it would do is 1.4 @ 1.65 Vcore. Not bad, but not what I had hoped for. I sold the 1.0A and got a PIII-S 1.26 512K CPU.
I put my PIIIEB 1000 in while I was waiting for the new CPU. I was pretty surprised my CPU would not run 1.75 Vcore 150 FSB like it did on the CUSL2. I boosted it up to 1.8 (max Vcore on the Gigabyte board) and it worked. I was once again greeted by the hang on reboot problem (any reboot). I can understand a 1.475 CPU @ 1.65 needing a wire trick to get it to post, but a 1.75 @ 1.8?? That doesn't seem right.
I have some insight into why that happens. This is odd. If I dont overclock at all, 1GHz @ 1GHz, and use 1.80 Vcore, it will do the same thing! Hang on every reboot with no overclocking! There is definitely something wrong with the way it posts with a CuMine CPU.
My other gripe (hang on, the good stuff is still coming!!), was I could not get the 1/5 PCI to work. The PC will crash every time just before the desktop loads. The setting I used is 160 FSB PLL/16 30/60. I've tried F9 and F9D BIOS, 2 different video cards. Wont work. There is speculation it doesn't work on -C boards. I can say for sure, it doesn't work on my setup.
My frustration with the board got to me and I ordered a TUSL2-C. Its still not here. Hopefully, tomorrow. I am going to do my own little bakeoff between the two boards and keep one of them. I've run a bunch of tests and benches on the GA6OXET. I'll post em up once I get the TUSL2.
My PIII-S is here (we're getting to the good stuff now) . I have it in the GA6OXET and it.....................
FOOKIN ROCKS! This CPU is so sweet. So far, I'm running it 150 FSB, 1.425 GHz @ get this: STOCK 1.45 VCORE stock HS/Fan with ASII. I have Prime95 running for the last 1/2 hour, no errors. Also, no hang on reboot! Another little oddity I saw is the max Vcore for a CUMime is 1.800. Max for Tually is 1.825. Whats the deal there?
Things are looking up! This is the first combo I have been really happy with (thrilled actually). I'm still going to test out the TUSL2 and see how it does.
Couple of questions (if anyone is still with me).
Which BIOS is better/newer? F9 or F9D?
What kind of video card are the guys with the working 1/5 PCI divider using?
