- Nov 12, 2002
- Rootstown, OH
- Thread Starter
- #21
I was rather curious about this myself - do you have to apply a lot of pressure to make sure you make proper contact? Has it ever caused any issues?
mounting pressure is sufficient. on sandybridge, the retention clip is enough.
Removing sandybridge should only be done when warm. cold vaseline can damage socket pins.
wouldn't it be better if you install first the memory and ram before putting the vaseline? just curious..
Sort of. Except anything socketed on a benching mobo is being swapped around constantly. It part of the reason we dont use cases. The ram and gpu are in a different board every other day. Before reseating stuff, I repack the socket each time.
earthdog had a good point too.
