(I'm using PassMark's Performance Test currently, for what that's worth.)
I'm slowly cranking up the OC on my new 8350. I haven't got anywhere serious with this so far, but as I creep up the clock frequencies, I can see the performance score on my processor rising, but the performance on my disk scores is taking a real beating.
I took the 8350 up from its stock 4GHz to a simple 4.6 with just raising the multiplier and feeding it voltage. CPU scores went up a reasonable amount, Memory scores went up a bit, disk scores dropped by around the same amount.
Wondering about the relationship between this and the base frequency, I lowered the multiplier and raised the frequency to get very nearly the same CPU speed. CPU mark increased a very small amount, memory performance jumped quite a bit (cool) and disk scores plummeted. Not only compared to stock, but they're about 32% lower score than almost the exact same frequency but just using the multiplier.
What's causing this? And is there a way to OC without causing this effect? Disk performance is important to me.
Rig in the Sig.
-H.
Rig in the Sig.
-H.
