- Mar 11, 2003
This is thread for all phase-change questions, such as how it works, theory, etc.
Just post a question and I (and I'm sure others), will try our best to answer it.
So, I'll start off explaining how it works.
There are Five main parts to a basic phase-change system. The Compressor, The condensor, a restriction (cap-tube, valve), the refridgerant and the evaporator.
As refridgerant expands, it take sin heat from it's envorment, and as it condenses it gives off heat. So, you want to cool it when it condenses, and put it on your processor when it is expanding (boiling).
COMPRESSOR
The compressor, this is basically a very high pressure pump. It takes in gas, and puts it under enough pressure for it to condense. This adds a lot of heat to the gas, and so it has to be cooled by the condensor to avoid burning up the system.
There are several different kinds of compressors, rotaries, hermetic, semi-hermetic, and then ones driven by a belt or external motor, such as one in your car. For a phase-change system such as a waterchiller or direct die system; you will want a 1/6 to 1/2 HP hermeticically sealed compressor , just for ease of use and efficiency. I wouldn't go any smaller than 1/6hp, because otherwise you won't be able to have the desired high to low side difference in pressure and the correct refridgerant flow. Anything bigger than 1/2HP, and it'll cost a ton to run, and you can get basically the same temps with a 1/4HP or 3/8HP compressor as anything larger given the heatloads we'll be working with.
This is a piston compressor:
This is a rotary compressor:
Both are hermetically sealed.
Condensor
The condensor's purpose is to cool the liquid refridgerant after it comes out of the compressor. This condensor will get refridgerant that can be up to 55-60C, and should have it down to nearly ambient temp by the time it comes out.
It is needed for a couple reasons, first, otherwise the system would burn up, as the compressor continually added heat, it would burn up. Also, because once the refridgerant expands in the evap, it will get cold from say 30C instead of 55C, so it's able to pull in more heat from it's environment (which is the evap). So, this helps get the evap colder, and so your computer stays cooler aswell.
This is a picture of a fairly large condensor:
Restriction
This is usually a capillary tube, which is just a very small tube that restricts the flow of refridgerant. This is so that you can pull a very low pressure on the opposite side with a small amount of refridgerant, and it'll expand. This is the Evaporator.
You can also use a small valve, but for computer application it's generally more complicated than it's worth, and a cap-tube system works basically just as well, while being easier to setup. For a beginner, I highly reccomend a standard capillary tube setup.
I don't have a picture of this, I cna get one if anyone needs one, but I think it should be fairly self explanatory, it's a very small copper tube.
Evaporator
The evaporator is where the refridgerant expands, or evaporates. This is when it pulls in heat energy from it's surroundings, and makes them cold. Thus, it's like putting a -40C block of copper on your CPU, it makes your cpu cold. Or, if you're doing a waterchiller, it makes the water cold, and then you pump it through a block, and your cpu gets cold.
An evaporator cna be lots of things, it cna be a coil of copper tubing, a finned evap like in an air conditioner, or it can be a block that goes on your cpu.
A finned one :
A block (or direct die), can have many designs, and features, so posting one wouldn't really make sense, but here's a gallery with a bunch of them:
http://www.teampuss.com/forums/viewforum.php?f=30
Refridgerant
Refridgerants are almost always a gas at room temp, this allows them to expands a ton more in the evaporator, and give you better temps. There's literally hundreds if not thousands of these, with boiling points ranging from 100C to -250C, I'm not sure what else to say about these, so ask questions.
Some common ones are R22, R134A, R290 (propane), R404A, R507, and a bunch more.
This about sums up the basic parts, I'll make a post about more specific parts, and thenone on setting up a phase-change system later today.
Sorry about typo's etc, I'll look over this post later.
COMPRESSOR
Condensor
Restriction
Evaporator
A finned one :
Refridgerant
