- Jun 3, 2002
http://www.ocforums.com/showthread.php?t=370739&highlight=power+cost
For future reference, the Search feature is your best friend
primuslesler said:hey can you use freon as the refrigerant?
lowfat said:How can one tell the difference between a good compressor and a not so good compressor?
matttheniceguy said:Turn it on. If it seems to run well, throw a manifold gauge on the low side and see how much vacume it can pull. Is should pull down to -29" HG pretty quickly if it is still good.
When selecting compressors from a bin at the recycling yard, I tend to go for the ones that look to be in the best shape, and still have all their run components (start cap etc.). Some of them run, some don't.
greenmaji said:btw.. Rysjimmy1994... from what Ive read pelts seem to not help after about -40C and a good single stage direct die or a big liquid chiller seem to do that all on there own so having the pelt on it would likely just get in the way (from my understanding of it) every user Ive seen that says you can run them 24/7 says that you can only do it with HEAPS of insulation / dilectric grease the works.. maybe you should look around for more info. on the subjet? seems Ive found heps. on the web so far...
greenmaji said:There are a few refegerants that you dont need a licence to use.... propane seems to be a popular one
Time4aMassiveOC said:so most of you you DiY phasechangers are serious criminals!!!
