I am glad you guys are learning all of us for this. I think I am going to play with some of the ubuntu stuff today with my e8400 system. It is slow, but is currently the only 'spare' smp system I have sitting around.
DD step 20504619 load imb.: force 12.4%
At step 20504620 the performance loss due to force load imbalance is 5.3 %
NOTE: Turning on dynamic load balancing
Just to compare note's Steve, its not just you. I have slowed down on every WU.Oh, another thing I could try....
When I re-installed my linux to make it EXT3... I followed the instructions as to NOT update it (writing issues after the "....Done" even in ext3)... I could try to only update the Kernal, as the noticeable increase in time happend after I reinstalled to ext3... I thought I seen a guide somewhere as to using a spesific kernal...
curently running 2.6.35-22-generic
Are you referring to TPF becoming longer within a discrete work unit between download and finish or are you comparing more than one work unit out of several?slowed down on every WU
Unfortunately I am away a bit, and really only have time on the weekends to physically be at the rig. I could probably get that info out of HFM. I'll have to check on that...Also its more productive to just let it run below peak performance rather then risk a lost WU.Are you referring to TPF becoming longer within a discrete work unit between download and finish or are you comparing more than one work unit out of several?
Also, have you checked the load imbalance entries in the wudata log? If all load balancing is properly engaged and the computer is doing nothing but Folding, the load imbalance should be 3% or less.
