- Aug 29, 2002
- Corona, Ca
After about 2 weeks of this one running, it started randomly restarting, geee I wonder why hahaha
JDXNC said:Typical HP board, I've had to fix several of them for the same reason, the caps just can't take it when the cpu is at 100% for a long period of time. Easy fix though.
eaglescouter said:Very interesting. Of all the rigs I run @ 100% load I have never experienced this problem.
Ouch. In that case, thlnk3r, you might want to consider replacing even the ones that aren't damaged, just in case.JDXNC said:Typical HP board, I've had to fix several of them for the same reason, the caps just can't take it when the cpu is at 100% for a long period of time. Easy fix though.
JDXNC said:Was only a couple models affected, can't recall them of f the top of my head, but they were from the era of the whole stolen electrolyte formula problem.
Hamm3r said:Yeah it used to happen on some of the older boards. My MSI kt133 board died because of the same problem. So I replaced it with NF7-S
JDXNC said:The most common problematic boards I have seen have been from Abit and ECS, but many manufacturers were affected.
Dk Jedi Allianc said:I think that Epox 8RDA+ had the same issue, if I remember correctly...
Anyone have a good guide for replacing the caps?
