- Sep 5, 2002
- Toronto, ON
I'm using my TV Wonder (not VE) in Windows XP right now, so it must've been some sort of conflict like you said.
JohnnyTheRed said:Looking to watch and record shows from my cable, vcr, and such. So I'm looking for a video capture card. But I don't know what good names are, or even what to look for.
Are video tuners the same as video capture? Or do video tuners need software to capture the signal?
What about output formats? Are AVI's better than MPEG's? Vice versa?
- Thanks for all the info.
Pyros said:I have the Leadtek Winfast TV2000XP Deluxe capture card and I highly recommend it.
JohnnyTheRed said:Would a card designed for capturing analog signals, still be able to capture a signal from a digital cable source. Is there a difference? If it can, will there be any degradation in the signal, or the quality of the captured image?
DaddyB said:
No problems with PCI cards but as Malakai said stay away from USB 1 devices (USB2 and firewire ones are propably OK but I don't know).
JohnnyTheRed said:I'm still trying to find as much informatin about a handful of cards as I can.
Namely the Hauppauge models 880, 980, and 990 (WinTV PVR series). And various ATI cards.
When you say AVI takes insane amounts of space to encode to, about how much space would an hour long show take up? And then again, how long would it take to encode it with software to MPEG1/MPEG2 format?
- Thanks
RoadWarrior said:I was just thinking about some things.
VCR control.
Just for a tuner, there's some older top loader VCRs out there that didn't come with a remote. They have a socket to plug a remote module into. Just thinking it shouldn't be all that hard to rig something up to the parallel port to switch channels.
Also, some motherboards have a IR option instead of com 2. If you find/buy/make an IR module for the header, there's probably shareware out there that will let you control anything, cable box, VCR, etc, etc.
JohnnyTheRed said:For my budget, these cards still have my attention:
Leadtek WinFast TV2000XP
Anyone with firsthand experience with any of these? Good experiences, or horror stories?
madcow235 said:Since we are on the subject say i get 5.1 channels such as hbo and cinemax can i use the 5.1 on my sound card while my tv card is in my comp. Bleh that sounds retarted maybe someone will understand me.
