- Thread Starter
- #41
Rio71... thank you, thank you, and thank you.
You are the only person that was able to answer the question. Not only that supply a link to the program that CAN shut it down.
Man the BS I had to encounter in this thread just to get an answer (like I don't already know the dangers).
So there IS a way to switch off thermal throttling.
I just tryed it by unplugging my fan, went upto to 80c before I repluged it back in.
Sorry I can't read german, but the program is simple to use, just untick Thermal Mon box for each logical processor.
I loaded up Throttle Watch, and there was no Throttle Graph, and it had been disabled in the options, therefore meaning thermal throttling is total switched off.
BTW. changed my sig specs, since cpu 3.8ghz / mem 475ddr / vid 580/1180 might be my highest overclock, but its no longer 24/7 due to low fan speed through out the case and thermal throttling.
-With the throttle off it will just crash, with it on then 3.8ghz is invalid.
-New sig spec settings, moving next to no air and cpu temp is 60-65 (out from throttle zone (25-30 room temp), primex2, atitool open, running other stuff. Right now its only 18c in my room, and cpu is close to idle, temp is 36c.
-Video card voltage has been dropped also, hence the speed. lol, peoples told me that my video card would last a few days to a week with 1.675v into my X800 core on air cooling. It lasted 6 months, and it still going never slowing down till I tuned it down.
Rio71 said:hi,
Question 1:
yes, the thermalthrottling is absolutely undepening of the temp-reading on mobo.
Question 2:
you can set the thermaltrottling to off with the little tool " ctp4 ".
check or uncheck the field and it works direktly and non permanent.
