Okay, here are the first pics and my initial feelings
Opened box and here this little beauty. It looks so small in real life!
Cooler in bag. Typical well packed in foam for protection
Cooler and fan are so nice! Quality is excellent but I didn't expect anything less.
Heatsink base is 40x42mm with 6x 6mm pipes. There are 2x 2mm wire braces from opposite side of where pipes come out that attach into cooler so they can't get bent easily. A nice touch showing the engineers are thinking. Sorry they don't show better in picture. Will try to get a better shot of them and edit it in.
AXP-100 has a 2mm wire brace built into from base to radiator.
The supplied 120mm fan adapter plate.
The usual mounting kit for all Intel and AMD. Not much I can add. Bunch of little screws and 2 sets of knurled nuts
http://i14.photobucket.com/albums/a331/doyll/AXP-100
/AXP-1007mountingkit_zps2e4978d2.jpg
and lastly the screws for 120mm fan mounting plate, TY-100 fan and thicker 120/140mm fans
This is one very nice little cooler! Good attention to detail and quality. I can't wait to try it out and see how well it cools!
I could ramble on and on with all the measurement and weights but they are all on Thermalright's website.
http://www.thermalright.com/html/products/cpu_cooler/axp-100.html
All I have to test right now is i7 920 on EX58-UD3R. I'll use Thermalrigth Macho HR-02 for baseline comparison.
I will present my results in bold text. Hope this makes it easier to scan to see results.
Thermalright Macho HR-02
on i7 920 stock
Handbrake @ realtime
Cooler Intake . Idle CPU; rpm; Cooler Exhaust . . 100% CPU; rpm; Cooler Exhaust
21c . . . . . . . . . 30-28-33-27c 650rpm 24.5c . . . . . . 54-54-56-53c 950rpm 29.0c
First pass
Thermalright AXP-100 w/ TY-100
on i7 920 stock (130watt CPU)
22.0c. . . . . . . . 37-36-40-35c 1000rpm 31c . . . . . . . 65-65-66-63c 2400rpm 35.1c
22.0c. . . . . . . . 32-3a-36-31c 2400rpm 26c
TY-100 is almost silent below 1500rpm. Progressively louder as speeds increase. There is a slight hum at high speeds.
Noticing vibration noise dependent on rpm.. Smooth to 1500rpm, maximum is 2000rpm and smooth full speed. Assume this is a defective fan and not normal. Tested using voltage fan control and get same so not PWM related. I assume this is a defective fan as I've never had this happen with any other Thermalright fan.
Ran a second pass after 30 minutes idling and got exact same results. See no need to run a third pass. Changed to TY-140 fan and testing it now.
So far at idle 39-38-43-38c @ 725rpm.
on i7 920 stock
First pass
