- Apr 4, 2011
Okay
Found the shroud and mounted it between TY-140 and AXP-100. It's 15mm thick. 140mm diameter to 107x114mm rectangle.. fits perfectly on AXP-100 120mm mounting plate.
AXP-100 w/ TY-140
Tested with i7 920 stock
Handbrake @ realtime
Cooler Intake . Idle; CPU; rpm; Exhaust. . . . . . . 100% CPU & Fan rpm Cooler Exhaust
23.0c . . . . . . . . 37-35-40-34c . 700rpm 31.1c . . 69-68-70-69c 1200rpm 38.8c
24.0c . . . . . . . . 35-34-38-33c 1280rpm 29.1c . . 67-67-68-65c 1280rpm 38.0c
23.5c . . . . . . . . 32-33-38-33c 1280rpm 28.0c
TY-140>shroud>cooler
23,0c . . . . . . . . 33-32-37-32c 1250rpm 27.5c . . 65-66-67-65c 1250rpm 33.8c
22.5c . . . . . . . . 32-31-36-30c 1250rpm 26.5c . . 63-64-65-62c 1250rpm 35.5c **
**Last pass I turned base 90 degrees so it was better fitting the AXP-120 adapter mount.
nice results with the shroud
I really tempted to try one on my HSF
can you post a pic with the shroud mounted on?
