I've built system with the Thermaltake Pacific RGB fittings + Riing Plus fans only to discover the Thermaltake controllers are different and don't connect... The Riing controler attaches to usb and can chain. The Pacific RGB controler has an unused 5 pin connector that doesn't match with Riing controler chaining... Also the Pacific RGB (fittings) can't attach to the computer to control...
Thoughts?
The fittings have a 4 pin fan connector which drives the LEDs. Can I rewire to the 4 pin rgb headers on the motherboard?
Thanks.
Thoughts?
Thanks.
