YellowDart said:WELCOME TO THE FORUMS!!!
It depends on what you want the computer to do...
Gaming, video, graphics??? Or just email and homework??? Are you planning on oc'ing your CPU???
If you're not going to oc... then the Tt Spark 7 is a good hsf. However, if you are trying to push more out of your rig and decide to oc, then I would go with one of these two...
Zalman 7000Al-Cu -
Thermalright SP-94 -
Google either of these, I'm sure you'll get plenty of info/specs. Actually overclockers.com has interviewed both! Check them out. You'll get better cooling out of the Thermalright... the only drawback is price, and the fact that it doesn't come with a fan. But you can put your choice of any 80mm or 92mm fan on there!
Good luck with your new rig!
Well i also have a 2.8c and am stuck with the same two options... could someone link me to both "interviews" please
thx
Ritalin
Zalman 7000Al-Cu -
