- Jun 24, 2002
- California, US
I am going to be building a new case out of plexiglass. The reason is my PC-60 case is really too small for watercooling(well it's watercooled now...... but I'm bored ). So I want to put the HC down in the bottom front with every crack and hole sealed up with rubber or liquid nails. Then I want to put in 4-7 80mm 21db fans for exhaust. This should pull only air through the heatercore and cool all the components in the case.
So I suposidly would get maybe 150-200cfm going through the HC with low db.
I also have a 172mm fan that on 5v is probably 30db... not sure on cfm but I'm sure its a lot more than one of these 80s. Would having 3 of these be better? They are a bit heavier so maybe it would cause stress on the plexiglass?
Would this work? Anyone try this before?
Edit: I also want to sound deaden the whole thing, cept for the HC and where the fans are. I'll probably use the cheap melamine.
