- Dec 13, 2015
As the title says, I'm looking to build a good gaming rig that will last me 3 to 4 years if possible. I have the case picked out, the Fractal Design Define R5, but I need help on a good motherboard, processor, whether I should go with mechanical and SSD hard drive or skip one or the other for storage. I'm looking to just go with air cooling, as I'm not going to overclock, so I don't need good water cooling ideas. I guess I'll need good memory too. 8 GB should be enough for now, don't you guys think? Or should I go for 16? Also, I've decided on the Sapphire R9 390 video card, so I don't need help there.
I've always had AMD processors just because they are cheaper and I feel the heatsink and fan is easier to install than on the Intel chips. The newest games, like The Witcher 3 and Assassin's Creed Syndicate, call for the FX 8350 CPU. I'm not sure that would last me beyond those games, though. Obviously, at this point, there are no specs for games like Mass Effect Andromeda as it doesn't come out for a year. However, do you guys think the 8350 would last me a while?
As far as the SSD, I'm not sure what they are for. Could someone give me some ideas as to why I would use both a mechanical and SSD drive? Obviously, the SSD's are smaller for now than the mechanical drives (250 to 512 GB vs multiple terabytes for mechanical drives). Actually, I saw there are terabyte SSD's but they are way to expensive for me with how good I want the rest of the build to be. Are people using their SSD for the OS and then a mechanical for all your programs and such? Is that why I would have both?
Thanks for any help that can be provided.
