I would rule out the cooler master with your PSU and GPU. They probably would fit, but it would be very tight. Air 240 isn't really that much bigger of a case and will give you a lot more flexibility and features. And bottom line, the CM is just a cheap case. It can't really compete with the rest of these and it shouldn't be expected to since it's half the price.
The Air 540 is way too big for my tastes. It will have, by far, the best airflow, but it is pretty big.
I did a build for a friend in the Mini R2. Awesome case. Great airflow, which makes it extremely quiet. It has all the features which make the Arc series awesome.
For me, it would be between the Mini R2 and the Air 240. Feature and airflow-wise, they're gonna be neck and neck. Dust filters, rubber grommeted cable mgmt, nice looking, easy to build in... You'll get a slightly smaller overall package with the Corsair, but a little higher quality "feel" from the Fractal. Both are excellent choices and I would go whichever you like the looks of more. Watch YouTube videos and read some more reviews, but they're both awesome.
I think I linked a Reddit thread a while ago with a write up on GPU clearance in the 240. Basically, you have nothing to worry about. There are pictures of a guy with a 308mm 970 G1 installed plus a front mounted 240mm rad. You'll be able to fit any card you want in there lengthwise.
Do check in card height tho. Most will fit, a few might give you issues.
The Strix 980 is a great one. It was a coin flip for me between it and the G1. I think the Strix would have been quieter, which I probably would have valued more.
