Just because I work on CRT TV's does not mean you should. I took a electrician course for working on everything from CRT's to transformers and have both the skills and tools to work on something like this. A CRT TV can and will kill you if you don't know what you’re doing.
Now that we got that out of the way.
I have an Über high end TV from 1982 that I fixed up to play old games on.
But there are a few things I have not done to it yet. One is replace/recharge the tube and the other is to replace all the capacitors.
Right now I have it (most likely) at 90ish% of its original picture quality in B&W and about 80% in color.
I'm not all too knowledgeable with older CRT TV like this one. If it was a later CRT monitor or arcade monitor I would have it working like new.
SHORT VERSION:
The color red is over driven and the TV is from 1982. Would you replace all the capacitors on the IC board?
LONG VERSION:
The color red is over driven and I have to lower the color to keep in line. I believe this would mean that red it being over driven (too high of voltage) not knowing what voltage it needs I can't do much to fix it. That or a bad tube witch I can't see do to its already amazing picture quality. I do not have a tube tester so I can't test it right now. (Last one broke) The picture is also a tick fuzzy.
I rebuilt the neck board which helped a lot. I have also tuned everything I can tune. Now my thoughts are to replace the caps seeing as the tv is from 1982
Safety 110% aside (I have worked a quite a few CRT monitors) would recapping it be worth the trouble?
The TV's IC board has quite a few caps on it. My only problems are all the wires on the board. There is like 100 wires and I would have to remove and label all of them
I have never dealt with a TV with so many caps before or one this old. I mostly work on CRT monitors and arcade monitor which are not quite the same. So I don't really know if replacing the capacitors would be of any help and not having a working tube tester does not help ether.
What would you do? Recap it? Deal with the red being over driven? If I lower the color red gets inline but then I have washed out color. It is not really that bad until there is a lot of red on the screen. For example when I'm playing virtua fighter 2, the level with Jacky has a red hazy overcast and sometime Kage glows red.
This old TV is kind of scary; it's not like anything newer. It even has a warning label on it saying that you need to wear a lead vest when working on it That would explain the fuzzy feeling I get when working on it
Of course I have no problem working on it, I just have to be extra careful. It has a warning on it that say the flyback can hold as much as 200kv at 100amps.
SHORT VERSION:
LONG VERSION:
