Heatfireash
- Jan 24, 2017
Hey all I'm looking to start a closed loop water cooling build. I've build tons of computers and have done 1 water cooled pc so far. Here are my current pc specs. Cpu- Intel i7 4790k 4.0ghz: Motherboard- MSI Z97A: GPU- EVGA Geforce GTX 980ti superclocked: RAM- 16gb Corsair Vengeance pro 2400mhz: PSU- EVGA Supernova 1300 watt Gold: Case- NZXT Noctis 450: HDD- 500gb Samsung evo.
I'd like some advice on upgrades and therefore have some questions.
1. Is it worth it to upgrade the cpu and mobo, I know the new i7s just came out? This also means getting new RAM which could be a bonus.
2. I defiantely want to upgrade the video card as I'm looking to water cool it/them. Should I go to a 1080 or should I just get another 980ti and go sli?
3. I'm having trouble finding cases that can hold a a full closed loop system with a tank mounted water pump/reservoir combo. Any suggestions?
4. Will my PSU work still, I think that 1300 watts can should be enough power, right?
4. Lastly I want to use the rigid tubing for the loop. Is there any tips I should know before doing so? I've only used flexible tubing in the past.
Thanks for the help!
