Greetings and welcome to my hell. The past 10 months of my life have been solving behind this damn rig trying to solve its never ending/changing problem.
First of all, here are my specs (you'll probably need them)
EVGA nForce 780i SLI FTW ATX
Core 2 Quad 2.83GHz Q9550
EVGA GeForce GTX 285 2G
Crucial 2GB DDR2 PC2-6400 x 4
Corsair TX750w
Western Digital Caviar Black 1TB
LIAN LI Lancool PC-K7B Mid Tower
ViewSonic VX2433wm
Let's get to the bottom of this. So my problem.... Random lock ups
I built this rig back in May of 2009, it has always had this problem... until i put of small house fan in the side of my open case. It worked, but ever since getting sick of having cold feet and a loud fan right next to me, I started asking for advice from knowledgeable sources, they all said, its the video card. So I RMAd it after talking with tech support who agreed. No difference. Still worked with the fan on the case. Still froze without it. No overclocking, no underclocking, and no messing with settings.
So then I was told that it might be my northbridge over heating, or my CPU.. I checked realtemp on my CPUs to see if they were overheating.. Ran them without the fan, while playing WoW and Bad Company 2. Normal temps of about 55c-45c-47c-47c.. still froze. Did the same thing with the fan, and no lock ups. All fine, slightly cooler temps but not drastic. Got sick of it and RMAd my mobo... Guess what? Nothing changed. same temps, problems, except this time I couldn't even play a game WITH the fan running. Locked up almost immediately when I started playing or a few minutes in without the fan. Inevitable lock up even with the fan....
But that is nothing. Since I built this computer I have replaced nearly every component in the order of OS, HD, +1 house fan, GPU, Monitor, Mobo, RAM, and the CPU... Same problem persists through all replacements and testing... I have a feeling it may be some random BIOS setting that I'm missing.
I've tried just about anything and everything. This is no ordinary issue. The only permanent solution I found was the house fan. And now that doesn't work, even with all of my new components.
Also, right before I replaced my GPU, I started getting some artifacting (which lead me to believe it was the GPU).. It wasn't serious artifacting, It only appeared where shading was. Even in the BIOS, if you looked close enough, you could see it. Random pink flickering in the shaded areas on the windows 7 log in screen, around windows, in my shamans chain heals, fire in wow, looking at the sun in MW2, etc... installed new drivers to no avail... Then I bought my monitor. The problem seemed to be fixed with the artifacting, or so I thought..... But noooope, I started noticing it in the same areas, just more concentrated and less noticeable and only happened when I moved the camera or the piece of shading was moving across the screen. It wasn't on the loading screen or BIOS, and still only remains in games.
After replacing my mobo, the artifacting moved to my desktop where it really defines/enhances the ghosting on my monitor by making pink lines and such.behind letters while theyre moving, really noticeable when moving around a sticky note, it appears behind the line where the tones of color come flush.
Sooo sick of trouble shooting this rig. I'll be trolling this thread until my issue is solved, so ask questions, give advice.
Thanks
Corsair TX750w
ViewSonic VX2433wm
Thanks
