- Apr 6, 2009
- WI
Field Value
CPU Properties
CPU Type Intel Pentium 4
CPU Alias Northwood HyperThreading
CPU Stepping D1
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.00GHz
CPUID Revision 00000F29h
CPU Speed
CPU Clock 3230.5 MHz (original: 3000 MHz, overclock: 8%)
CPU Multiplier 15x
CPU FSB 215.4 MHz (original: 200 MHz, overclock: 8%)
Memory Bus 215.4 MHz
DRAM:FSB Ratio 1:1
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID 03/30/2005-i865PE-W83627-6A79AA1BC-24
Motherboard Name Abit IS7/IS7-E/IS7-G (5 PCI, 1 AGP, 4 DDR DIMM, Audio, LAN)
Chipset Properties
Motherboard Chipset Intel Springdale i865PE
Memory Timings 2.5-3-3-8 (CL-RCD-RP-RAS)
PAT Disabled
DIMM1: Corsair Value Select VS512MB400 512 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz)
DIMM2: Kingston K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM3: Corsair Value Select VS512MB400 512 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz)
DIMM4: Kingston K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS Properties
System BIOS Date 03/30/05
Video BIOS Date 05/04/07
Award BIOS Type Phoenix-Award BIOS v6.00PG
Award BIOS Message
DMI BIOS Version 6.00 PG
Graphics Processor Properties
Video Adapter BFG GeForce 7300 GT AGP
GPU Code Name G73AGP (AGP 8x 10DE / 02E2, Rev B1)
GPU Clock 401 MHz (original: 350 MHz, overclock: 15%)
Memory Clock 333 MHz (original: 333 MHz)
does anyone think i could do more with this pos or leave it alone
CPU Properties
CPU Stepping D1
CPU Speed
CPU Multiplier 15x
DRAM:FSB Ratio 1:1
CPU Cache
L1 Data Cache 8 KB
Chipset Properties
PAT Disabled
BIOS Properties
Award BIOS Message
