c627627 said:Thorton arrived today. Results will be posted tomorrow evening due to a problem that I just traced to this 92mm fan:
http://store.yahoo.com/svcompucycle/en92vasphipe1.html
c627627 said:At newegg it's $5.99 instead of SVC's $11.99. Just so you all
know.
and here's the result of my test with this fan:
All default settings
1.) Enermax 92x25mm UC-9FAB fan NOT connected: All normal.
2.) Connected to FAN3 slot, system freezes at black BIOS screen.
3.) Connected to either FAN2 or FAN1, system does not switch on at all (!). All normal after the fan is disconnected.
4.) Thanks to hitechjb1's suggestion: "You have to turn the speed dial up (fully clockwise), otherwise at the lowest dial setting, the fan hesitates to start."
The system boots without a problem after I did what hitechjb1 said.
How can this affect the entire system not switching on??
Good thing I looked at this thread just as I was beginning to start my investigation into why the fan was causing this. Thanks for the hint hitechjb1.
c627627 said:1.) When they say 2.3 GHz @ 512 cache = 2.4 GHz @ 256 cache, what are your thoughts?
2.) I didn't install the thermal sensor on the Tt SF II, why can't I adjust the speed of the Tt SF II with a knob just like I can adjust the speed of the Enermax 92mm fan? I turn it, but the speed stays the same... what am I doing wrong?
3.) As posted in the thread, the Enermax stopped my system in it's tracks untill I did what you said. How can this be?
