Sorry for being the noob at this, but I'm trying to learn. As you may be guessing I'm relatively new at OC'ing and would like to do this right and understand it to a certain extent. I guess I have several questions, but since the first step is which cooler.. I choose the cooling section of the forum hope it's ok?
Anyways here are my specs:
CASE: Define R3, No PSU - Silver Arrow
PSU: 750W Corsair TX CMPSU-750TXEU 140m
Mainboard: Asus P6T Deluxe V2 Intel X58 DDR3
CrossFire/SLI
CPU: Intel Core i7 930 2.80 GHz 8MB Box
130W S1366 (currently at 3150mhz = 150 bclk)
GFX: MSI N480GTX-M2D15 - GF GTX 480 -
1.5 GB - DirectX 11
RAM: Corsair 12 GB kit DDR3 1333 Mhz 9-9-9-24
HD: Samsung 1TB SATAII/ 7200 HD103SJ
I'm tring to understand it all I've been reading posts, forums, guides you name it, alot this last week but I wouldn't say my complete understanding has moved all that much. Here are my main questions.
First which cooler would you suggest I choose? (I'd prefer one that is able to handle up to a 4ghz overclock on this CPU)
And yes I'm currently running with stock cooler so this will all be theory until I get my new cpu cooler.
The minor OC'ing I've done so far was after making sure in several places that there would be no harm to this and I have monitored my CPU temps ever since (no real increase) but then again, very small OC.
What I've done so far is go to bios disable auto OC option and set it to manual. Then changed Bclk value to 150 which gives me 3.15 ghz as opposed to the 2.80 default speed of the CPU. Then I set DDR to 12xx (for some reason if I left this on auto, it downclocked the ram to lowest settings 10xx something like that?) considering my ram are at 1333 I assume it's safe as long as I don't pick anything higher than 1333 in this setting right? Do I understand this part right?
Anyways my goal is to reach 3.7-8 ghz with this CPU, so after I buy my cooler I need to understand what I have to experiment with to reach it. Why is it you can't just settle for changing these few settings I have changed with my current stock cooler? I mean Bclk, ram frequency and disabling of speedstepping? Why do I have to experiment with voltages etc. and how do I know how much I should change the various settings as I go along?
Why is it I can't just set my Bclk to whatever equals fx 3.7 ghz, see if it's stable with tests under prime and be a happy monkey?
Hope someone has the patience to help me out and please ask if you need anything clarified. Please don't refer me to sporadic guides a newbie can't understand anyways, I have really tried to understand what all these things mean and while I do understand it abit more than before, I still don't feel knowledgable enough to tinker with this stuff more than I already have...
Anyways thanks in advance!
CrossFire/SLI
1.5 GB - DirectX 11
