Hey Joe, I figured I'd hop over here (from TPU) to update the status on the chassis so everyone here knows what's going on.
The project started in 2008 and since then a handfull of companies like Dell and Falcon Northwest have released SFF/thin ITX gaming systems but this will be the first chassis available to the public for building your own systems.
At the moment, some parts are in production while others are in finished and in stock waiting for assembly. I'm still waiting on quotes for the sheetmetal and to hear back from the anodizer about the questionable finish quality on my test samples.
The original design called for an SFX power supply and a few companies have put out some impressive SFX units but after testing quite a few of them, it became obvious that they fall just short of enthusiest's power demands and make too much noise under load.
With high-end GPUs demanding 250w and overclocked i7s eating another 150w, it was clear that the SFX power supplies couldn't sustain the load, or keep quiet doing so.
I decided to modify the design to accept an ATX power supply. The supply is a modified 500w(cont.) Antec unit and included with the chassis. The only modification was to eliminate the bulk of the wiring and reduce it to a minimum.
The first 50 units are a trial run to provide samples to reviewers and work out any kinks they might find. Techpowerup.com and Overclockers.com will be the first to recieve production samples.
Enough already, what is it?
Titan ITX is manufacturing various ITX-based PC chassis. The first to be released will have the following specs...
ATX power supply (500w continous. 12v1 18a, 12v2 18a)
ITX motherboard
2.92"(73.66mm) of height for CPU cooler
1x 2.5" HDD bay
1x 3.5" (or two more 2.5") HDD bay with anti-vibration grommets
1x slot-loading slim optical drive
4x 80mm case fans (place as required. Two silent fans provided.)
Manually adjustable fan controller (internal) with motherboard PWM compatability
2x front USB 3.0 ports
Front headphone/mic ports
Optional front panel display
Designed for horizontal positioning in a home theater or desktop environment.
Top and bottom panels do not contain any venting holes.
And what you've all been waiting for...
Full size GPU support up to 12.3" in length.
The chassis is made from 14ga anodized aluminum with a solid anodized aluminum faceplate. The HDD LED was omitted and the power LED shines through a small hole to limit it's anoyance. The entire chassis slides out of the rear of the enclosure for easy access to the components. All drives are mounted to a single removable tray for ease of replacement. For those who don't wish to use a graphics card, an optional harddrive bracket can purchased that supports two more 3.5" HDDs, on grommets of course. This gives you 12TB (3x4TB) of storage potential in addition to the 2.5" SSD for your OS. The 80mm fans are easily removable for replacement.
It is aproximatly 0.456 cubic feet (12.9 liters) in volume with an external dimension of 14.831"(w) x 3.96"(h) x 13.44"(d)
I'll update the thread with details as things progress. Here's a short youtube vid.
Pics in a moment...
ITX motherboard
1x 2.5" HDD bay
