- Sep 7, 2013
Getting a lot of nah's and no's. I'm actually kinda shocked!!
Thought there would be some heavy peer pressure here.....
Not on a chip this expensive!
OK so your saying re-using the IHS plate makes only maybe 5c difference at best. Ya I can see that....
The point of why I de-lid is to not use the IHS plate at all. Why spread heat, I wanna transfer it before it's spread.
A later thought comment:
Replace Solder with TIM to directly contact the waterblock. Diamond particles measuring 0.0000015 cm rated at 8.3 w/mK or something of the sort within the paste.
Now removing that plate that seems to accumulate heat, then transfer it to the water block seems to make for a slow process.
Since Copper and Silver are really close together for conducting heat, It doesn't matter which is used. temps don't drop enough to replace copper plate with silver. But every little bit helps, so along the way, tried it.
In theory the IHS plate isn't really needed. It's dummy proofing really.
In the end solder is garbage for conducting heat. Taking IHS plates off AMD chips has done nothing but helped.
No, im saying removing an intel soldered IHS and going bare die with liquid metal will end with roughly the same temps, up to max 5c better, doubt AMD is much different. Removing solder and going bare die with paste you will see worse temps, ie you are not accounting for surface area. I tested this long ago with intel i950, as did ?fallwind on extreme, many years ago. He even tried water directly to die, which told him up front that wouldnt work.. Multiple people now have tried bare die with liquid metal vs ihs back on with liquid metal the temp difference is 4-5C with IHS on or off, if liquid metal used for both. liquid metal is 40 w/mk. intel solder is 87 w/mk.
Intels solder conducts heat at 87 w/mk. best paste is about 5 w/mk when tested in independent labs, but whether 5 or 8...at 8 w/mk that is 11x worse than intels solder....I linked the specs above.
So where do you see solder is bad a conducting heat? Are you saying intel is wrong in posting there spec of 87 w/mk per link/quote from intel paper above?
um... brand new 9590 is $208... cheapest 8 core fx i see is $130... doesnt sound like selling the one to buy two is really that possible...
um, the op lives in the USA where everything electronics related is a good bit cheaper than in Canada. In the states you can get the 95 watt 8310 for about $100 as they frequently go on sale. And the tray edition 9590 is $234.99 not $208.
Intel uses indium solder. The conductance of indium is 82 w/mk. You cant just use any solder on a chip, and no one has used leaded solder on cpus in many years. There is an entire corp called Indium via intel that sells indium solder meant for cpus... has to be soft, correct melting temp, weather thermal cycling without voids or damaging chip, etc.
Any intel cpu that uses paste, because of the thick bondline and poor 5 w/mk intels polymer tim conductance, yes you get big temp drops. if you delid for example intel 4790k, and substitute 60 micron thick 5 w/mk paste for 10 micron thick 40 w/mk liquid metal, then temps can get 20C lower. If you then go bare die with liquid metal, you can decrease temps another 4-5C. There are hundreds of people including myself (I have posted my temp drop) that delidded 3770k/4770k/4790k and subtituted intels very thick 5 w/mk tim for a very thin 40 w/mk...that is the big temp drop...but whole reason everyone started delidding is because intel quit using indium solder 87 w/mk, and using much worse 5 w/mk paste.
If there was an air gap, the processor would throttle at any load at stock....but that isnt the issue. the issue is the thick bondline caused by the adhesive, and question if partly design to minimize thermal cycling tim fatigue.
But solder is 87 w/mk, and whole point of delidding is because intel quit using the better solder. I would take a soldered chip over a delidded chip anyday, as would 99% of those that delidded their 4790k/4770K....should see all the threads complaining about intel no soldering the mainstream chips....hence the paste...hence the delidding craze.
I have run bare die before, have pics somewhere on xtreme ? 8 yrs ago. you have to remove the socket and easy to get uneven pressure that causes buggy ram channels. Pain in the neck for an additional 5C gain over using IHS with liquid metal. If mobo sockets and cpus came ready made for delids, and chips I want had paste, not solder, and socket retention mechanisms were in place to help with uneven pressure...then no problem with bare die....but too much hassle, too little benefit. But delidding paste chips, yep those I would if temp limited.
But to each their own. If you want to delid just for testing, im all for it, the entire reason I did it. Just wouldnt expect much temp gains from bare die vs solder. And if you got a big temp drop with solder, that would only be possible if solder joint had failed...ie huge voids.
Any cpu that has paste tim will be around 5 w/mk, just arent any much higher ones used in tim1. But I dont know which amd cpus use paste vs solder for tim1, recently I have been more intel. my guess is if you search a particular cpu for delid...someone will have done so and can see
Do you know if AMD suffers from the same problem of using lower quality TIM inside the IHS????
I know.... The only way to find out is to de-lid a AMD FX-43xx/63xx or some 8320/8350 CPU's.
I never looked at that, as to me this was for Sub-Zero benching only and not water cooling
http://www.synonym.com/synonyms/dissipate/Spreading heat is not disipating heat. Simple as that.
Sense 2:
disperse, dissipate, scatter, spread out
separate, part, split
