- Oct 18, 2002
- Los Angeles
I'm using the Lepa LPWAC240-HF as shown here:
https://www.amazon.com/LEPA-Liquid-Cooler-Cooling-LPWAC240-HF/dp/B00RDLKYIC
I've had it since 11/2015, it has a 2 year warranty and it hasn't been a year.
Today the comp just shut down on it's own and threw a "CPU overheat" error, so i went into the bios and sure enough, 89 degrees...
Radiator is cool to the touch, even after i stopped the fans from turning physically with my hands, radiator stays cool. Fans run at full speed when the bios reports 89 degrees.
Bios reports 2900RPM on the water pump. Also, touching the waterblock (where the waterpump is located) i can feel vibration, can also feel vibration on the hoses connecting to the waterblock, so i think pump might be fine? Waterblock is HOT to the touch.
What could be wrong? There is no sign of a leak... and this is a closed loop system so what are the chances that there's a blockage of some sort in the water line?
I unscrewed the radiator from my case and sloshed it around to see if i could hear water, i didn't hear any...
Next I weighed the radiator by itself (I didn't detach the cpu block) and it weighed in at 2.33lbs or 1100 grams, I'm not exactly sure how much it should weigh, remember, this is just the radiator, which has two extra fans on top of the fans that it came with originally... So if there was no water in there, it should weigh significantly less than it would if there were water in it.... That's all the info I can get without actually opening up the closed loop system.
When I put the radiator back on, i disconnected all fans from it and ran it again, now the very bottom of the radiator gets warm and everywhere else it's cold... I'm thinking there's a tiny bit of water left in the radiator and that it somehow evaporated from the closed loop system.
What else do you guys suggest i do to troubleshoot?
